Broken mirror, cut and reuse. Tool?
I have a fairly large, frameless, wall mirror that recently had a corner broken off. I would like to remove the broken section and reuse it. Is there a particular glass cutting tool that one would recommend?
Removing mirror from wall without additional breakage will be a challenge if mirror was attached with adhesive. You can also expect wall damage and repairs.
Here's an old thread that may be helpful to you: http://forum.doityourself.com/archive/index.php/t-125122.html
