Mirror cutting for a new light fixture
Old 12-10-07, 03:01 PM
T
Ok, picture this. I have a large mirror in my bathroom and at the top of it, the ceiling begins and is angled in. Also the existing lighting fixture is a mirrored, contemporary long fixture with the bulb lights and is actually installed about 3 inches below the top of the mirror, sort of inset inside the mirror. What I want to do is remove that fixture, cut the mirror so I can replace the fixture with a less contemporary one and frame the mirror with a Mirror Mate. My problem is how do I cut the mirror while it is still on the wall?
Old 12-10-07, 03:17 PM
johnam's Avatar
Received 12 Upvotes on 11 Posts
Impossible to do by you or a professional. Have you removed the fixture? Is it laying on the surface of the mirror or is the mirror cut out and the fixture mounted to the wall?
Old 12-10-07, 04:09 PM
T
No, I haven't removed the old fixture. The mirror is cut out and the fixture is mounted on the wall in that space.
I was hoping I could remove the old fixture, cut the mirror at the bottom of the cut out area so actually I'd only be cutting a smaller mirror surface since I would only be extending the cut out area (am I explaining this right?) and then mount a new fixture in that space between the new top of the mirror and the slope of the ceiling, add a Mirror Mate around the whole mirror and then paint any areas that are left on that part of the wall.
Old 12-10-07, 05:05 PM
johnam's Avatar
I've got the picture but the mirror still can't be cut. I guess the fixture you want to use will not cover the space of the old fixture. You'll have to replace the mirror.....sorry.
Old 12-10-07, 07:54 PM
T
well because I also want to install a Mirror Mate around the mirror. Thanks for trying to help me. I don't know what I'm going to do now -- maybe remove the whole LARGE mirror and figure out from there. And here I thought it would be such an easy thing to do and finish up the redecorating of my bathroom -- that's all that's left is the new light fixture and Mirror Mate around the mirror!!!!
Old 12-14-07, 06:11 AM
E
Was the mirror cut around the elec. box. the two screws on the box hold the fixture in place. try removing the old fixture and see how its mounted.
