Skylight
I would like to know how I can attach a piece of glass directly to brick. Just to put you in the picture this glass is going to serve as a skylight. Shall I attached the glass directly to the brick using sealer? Someone else suggested a method of first hammering a wooden frame to the brick and then again by using sealer I attach the glass to it.
Also, can you tell me what thickness is usually used for skylights?
ROBERT
ROBERT
Post back with the details and we can better help you. Glass type depends on a few things. Type of glass depends on height from ground, location to a door and also let us know if you are intending an insulated glass unit which is thermopane. Making use of a wood frame is probably going to be your best bet and if done properly it will not leak. Post back and I can be more specific as to the set-up and installation.
