Broken glass in cabinet door
Old 08-25-16, 08:56 AM
I'm not sure if I'm posting in the right forum, but I need to replace a pane of glass in a cabinet door, but I can't find the same kind of glass. I guess I could get 2 more of the same, but I kind of like the one that's in the opposite door. Temporarily I just got a pane of glass at a big box store and spray painted with frosted glass. Any idea where I could find one to match. I'm attaching a picture. Thanks in advance!
Also, if this isn't the right forum, can you point me in the right direction?
Size:  26.9 KBName:  cabinet close up.jpg
Old 08-25-16, 09:01 AM
Shadeladie's Avatar
Super Moderator
Received 345 Upvotes on 276 Posts
OK, I moved it to "Glass and Mirrors".
Old 08-25-16, 09:55 AM
P
Received 1,772 Upvotes on 1,584 Posts
Check with stained glass stores. They have all sorts of decorative glass. I would have them cut it to size for you. Sometimes heavily patterned glass can be annoyingly difficult to cut.
Old 08-25-16, 02:49 PM
XSleeper's Avatar
Received 1,720 Upvotes on 1,544 Posts
I would take a door off and take it to a commercial city glass shop. That would be your best bet. Call around and see who has the most samples. Not all glass companies are equal.
Old 08-25-16, 05:30 PM
Thanks, I'll give them a call!
Old 08-25-16, 05:55 PM
Handyone's Avatar
I think once you walk into a professional glass shop with many samples, you will be impressed and might look at some other options.
Old 08-26-16, 06:03 AM
johnam's Avatar
Received 12 Upvotes on 11 Posts
This an old style patterned glass that may be difficult to find. It was called Bottom Bottle Glass and came in clear and a few tints. Your only chance might be an old glass shop that might still have some. Stain glass studios might also be a good source. If it only 2 cabinet doors it be cost effective to replace them with an available pattern.
