Picture Frame Delaminating
Old 04-20-18, 04:44 AM
Marq1's Avatar
Received 1,211 Upvotes on 1,099 Posts
Not sure when this happened but the laminate covering the frame has let go, only the top piece.
There is fair amount of tension so I doubt contact cement will hold.
Any idea what type of adhesive would have originally been used?
https://www.doityourself.com/forum/a...1&d=1524224658
Old 04-20-18, 04:52 AM
Received 875 Upvotes on 766 Posts
I would assume contact adhesive was used originally. Whatever adhesive you use - I'd tape the laminate down until the adhesive cures.
Old 04-20-18, 04:57 AM
P
Received 2,321 Upvotes on 2,065 Posts
Contact adhesive was probably used when the frame was first made. As a repair I'd probably use a two part epoxy.
