Hanging a big frameless mirror
Old 07-10-18, 07:36 PM
Got a tricky situation. I bought a big frameless mirror - the big polished edge vanity style - to install on drywall in a workout room. The mirror is 42 tall by 92 wide. 1/4 thickness.
Because I bought the mirror used, it already has plugs of dried epoxy on the back, which add about another 1/4 inch depth.
i was hoping to avoid gluing this thing to the wall, but Im not sure that mirror hooks will work. For one, even I drill into studs (which I would definitely do) I wonder if the little transparent hooks (the kind rated at 20#) would be sufficient to support the mirror. Based on 24 stud spacing in my basement, I only have enough length to use 4 hooks. Also, because of the dried epoxy on the back, the mirror wont even fit 1/4 hooks.
Am I stuck gluing it, or do you have other ideas? Is there a way to remove the epoxy from the back without damaging the mirror and using the plastic hooks?
Old 07-10-18, 08:50 PM
XSleeper's Avatar
Received 1,899 Upvotes on 1,705 Posts
You can use mirror j moulding on bottom and normal clips on top. If the epoxy is really that thick you will likely need to shim behind the j moulding and clips.
Old 07-11-18, 06:07 AM
johnam's Avatar
Received 12 Upvotes on 11 Posts
