mirror tiles
Old 03-13-02, 03:06 PM
mwickline
mirror tiles
Is there anyone that knows how one can remove mirror tiles from dry wall without damaging the dry wall. The tiles have been up for only 12 years.
Old 03-22-02, 12:16 AM
ske
removing mirror tiles
I haven't tried to remove mirror tiles but I think this technique should work: break the tile with a tack hammer by striking it in the center. Remove pieces until you expose the foam squares that hold the tiles in place (they should be on the back of the four corners of the tile. Use an eye dropper to apply very small amounts of laquer thinner to the foam square. The laquer thinner should desolve the foam square and allow you to gently remove it from the wall.
