insulating a greenhouse
Old 09-26-02, 11:17 PM
josh1
I have a poly type galv frame greenhouse around 24x12. Im looking to heat it mildly to overwinter some plants. Any ideas on insulation ? Thanks-Josh
Old 10-08-02, 07:46 PM
T
Received 1 Upvote on 1 Post
Insulating a greenhouse
If using an electric heater, make sure it has a temperature control so it automatically turns on and off. Make sure your greenhouse is 'tight' -- no cracks around doors, vents, parameter around the balcony, etc. A small leak will let a lot of heat escape. During winter, you can line the inside of your greenhouse with 4-mil polyethylene film. Double layer is better and can reduce heat loss up to 40%.
Other things to save heating costs:
Keep greenhouse cool at night - don't heat above 50 degrees. Grow plants with low temperature requirements or short growing season. For germinating seed (must maintain 70 degrees) build a small propagating bench with cover to keep warm. Solar heat storage -- add water filled dark drums or other material to capture and store heat during the day and release it at night.
Economically Heating (& Insulating) the Greenhouse. Charley's Greenhouse. Retrieved 08 October 2002. http://www.h2othouse.com/html/greenhouseheating.html#Q2
Go to www.h2othouse.com and www.charleysgreenhouse.com.
