Anchoring 4x4's for treehouse!
Old 06-05-04, 11:05 AM
Mike Jensen
I am building a 6wx6d foot shed with a "treehouse" on top- total of 12 feet high. How do you suggest I anchor the 4x4s on the corners- in the cement or on the surface to protect them from rotting with wedge anchors and steel holders? The 4x4's will obviously be carrying some load...
thanks in advance
Old 06-05-04, 04:31 PM
L
I would attach the posts to the concrete with Simpson post bases so that the 4X4's are an inch above the concrete. The shed walls will help stabilize the posts, but adding crossbracing in an "X" or a "V" pattern (Simpson CWB or WB), or even shearwalling the walls may be needed as well.
