Heating Greenhouse
Old 01-30-05, 10:37 PM
Heating Greenhouse
I have a greenhouse 9' by 20' and is 13 feet high sloping to 9 feet. Its a lean to style on my shop. I live in Northern BC Canada and need to heat it from about end of Feb to June. I'm thinking water heated floor. I need info about this system and a Canadian supplier if anyone knows about such things. Can't seem to find much on the net. The few I did find will not answer me. Buggers!
Supertech
POST EDITED: Posts seeking helpful DIY information for projects that are in violation of local, state, federal or International Laws are prohibited.
twelvepole
Super Moderator
Old 02-20-05, 05:12 PM
Water heated floor = hydronic radiant floor heating. CMHC page here. Also search "hydronic".
It's a good plan. Why don't you install this yourself? If you can work with pex or copper pipe, and pour cement, you can do the slab. For this greenhouse I would just lay foam insulation directly on the ground (above rain runoff), then a pipe and concrete wire sandwich on that, then pour. Then the circulating & heating units could be installed professionally or you might cobble something together with small electric water heater (operating at low pressure) and pump on thermostat.
Old 04-01-05, 04:44 PM
hydronics
Thanks man
Thanks for the info--hydronics was the key word I was missing.
Mike
Old 04-26-05, 06:26 AM
carson
green house floor
http://www.colostate.edu/Depts/HLA/G...ol_12_no_9.htm
The above has pictures toward bottom of article. I do not have but can tell you where to get a small pump that will circulate water through your complete water system for instant hot water.
carson HAPPY GARDENING
Old 04-26-05, 06:51 AM
Ed Imeduc's Avatar
Wink
You know unvented gas heaters are used the most. sure make the plants green. Will code let you do it up there.
ED
