Glass sliders for screenporch
Old 03-13-00, 05:59 PM
Guest
Post
I want to turn my screenporch into a three season room,Where can I buy glass sliders for this. Dimensions will be approx. 32"X54" but can be adjusted to accommodate a stock size.
Old 03-14-00, 05:39 AM
Guest
Post
Would need to know how your screenroom is constructed in order to answer your question. Is it wood frame or aluminum frame?
Old 03-14-00, 03:53 PM
Guest
Post
Wood deck 4X6 supports roof attached to house opening for windows can be adjusted.
Old 03-15-00, 10:13 PM
Guest
Post
Since your screen room is wood frame and the openings can be adjusted, I would suggest looking into single pane, aluminum frame, standard sized windows that are smaller than your present openings, at any home center. Then simply frame the openings to the proper size for the windows you get. This is a patio, so energy efficiency isn't an issue, since you aren't heating or cooling it.
