Patio enclosure
Does anyone have any experiences with companies like "Patio Enclosures" or similar type companies? I am interested in having an enclosed 3 season sunroom built. The size would be about 14x18 or 20 and I am wondering what the cost and quality would be, any help would be apprieciated.
Bob
Bob
Cost is going to vary a LOT, depending on things like where you live, who you have install it for you or if you get a kit and do it yourself, and what sort of options you might want to add, what sort of a surface you are installing this on, what wind and snow loads you have to meet (and what you have to do to meet them),...
I install them for a living. Do a lot of checking and looking before you decide which way to go (Contract it out or DIY). Unless you have done two or three, I would suggest that you consider going with a reputable contractor in your area. Miscut one part and you'll probably be waiting several weeks to get a replacement for it. It's not like being able to run to the lumberyard to get another 2X4!!!
Depending on where you are and what options you put into a sunroom, $100/sq. ft. is in the middle to upper end of the ball park. Sure, you can build a house for less, but it won't have extruded aluminum rafters (purlins) or Lexan (instead of glass) for some of the windows (and tempered glass for the rest of the windows), or a roof that costs $5/ sq. ft. for the material (and never needs replacing),... On the other hand, I've seen houses that cost $200/sq. ft. -- just depends on what bells and whistles the owner or buyer thinks are "necessary".
quote:<HR>Originally posted by quick6:
$$$$$....hold on to your wallet. I just visited a showroom today and the sq ft cost is around $100.00
I can build a home at less than $100 per sqft
and this stuff is pre-fab. How can this be??<HR>
Understand your points Lefty, but...still seems overinflated to me, the materials such as aluminum and foam are inexpensive and the pre-fab done at the factory should also help keep costs down. $100.00 per sqft of pre-fab materials still seems high to me.
The patio rooms and sunrooms that we install are anything but "pre-fab". our suppliers send us the parts that we order and make the windows for us. We don't alter the windows 'on-site', but everything else is cut to fit, on-site. It's up to the installing crew to adjust for things like the slope in the slab or deck we are installing these rooms on, out of plumb walls that we may have to attach to, getting enough roof overhang out of the way to acheive the necesssary pitch in the roof we are installing, juggling window and door locations to satisfy the whims of the customer,... It's not 'pre-fab' like bringing out a factory built modular home and plopping it down on the customers level lot, that's for sure. We have as much lee-way in constructing one of these rooms as a framing crew does in constructing a house, and in some cases, more. And each room is custom built to fit the particular location it is constructed at. It's no more 'pre-fab' than a site built home, where all the lumber is cut in a mill to specific specifications. What happens to that lumber on the job site is strictly up to the framing crew.
Understand your points Lefty, but...still seems overinflated to me, the materials such as aluminum and foam are inexpensive and the pre-fab done at the factory should also help keep costs down. $100.00 per sqft of pre-fab materials still seems high to me.<HR>
install a 30x30 screen patio?
louis guzman,
Welcome to DoItYourself.com.
You are talking 'screen room' -- that's going to be probably half the cost of a 'sun room'. They are 2 totally different animals!!
"30 X 30" is going to present problems. The roof can't span a 30' projection without some mid-span support. (No problem with the 30' width.) Using the aluminum "pre-fab" parts we were talking about, it could probably be done with a gable roof. A lot is going to depend on where you are, snow load and wind load that you have to meet, seismic zone that you are in, and what your local bldg. codes allow.
"manuals and kits" -- no such thing! You are given a set of engineering cut sheets. Not a problem for you though. Unless you are a licensed contractor AND an authorized installer, the distributor won't sell it to you!
