Very small "shed"
Old 05-10-06, 08:05 AM
Very small "shed"
I need to build a little pump-house type thing to cover a plastic water tank, protecting it from weather and sun. The size with be approx 2' square, 3' high. Construction will be PT 2x4 framing and 3/4" plywood panels (shooting for hurricane ready here...). I need to hinge both the top and front. It will sit on a concrete slab and be attached at the base with lag screws.
The problem I'm having is figuring out how to do the "roof". I would like to build it with a slope for water runoff ("shed roof" style) but can't figure out how to get the angle set up correctly on the frame.
I hope to do this simply and with as little cash layout as possible (of course )
Thanks for any tips!
Old 05-13-06, 04:01 PM
Hi,
Maybe this will help you,
http://pg.photos.yahoo.com/ph/charles_delape/detail?.dir=/2efa&.dnm=210are2.jpg&.src=ph
charles
Old 05-13-06, 05:08 PM
Sure might! Thanks much!
Old 05-14-06, 03:11 PM
Very small "shed"
Make the slab a little larger so you have room for an emergency generator next to the shed.
June is coming and the water is warmer this year!
Dick
Old 05-15-06, 04:51 AM
Dick
That's a good idea but won't fly as this area is visible from the street. Generators have to be hidden around here, chained down too
