2x4 or 2x6 for rafters on a 5 sided shed?
Hi,
I'm building a 8' five sided corner shed. The framing has already been completed, 2x4 16 OC for walls. Longest span from wall to wall is 8'. I'm trying to design a roof, thinking of using a hub in the centre with rafters, (no cross braces, planning on using hurricane ties for additional support). Planning to do the spacing at 16OC for the rafters with 3/8 ply on top.
I'm trying to figure out if I should be using 2x6 or 2x4 for the rafters, (slope 6/12), or perhaps a combination of 2x6 for the common and hip and 2x4 for the jack's. Any advice would be helpful.
Thanks
Jake
Thanks
Jake
I have seen some 5-sided shed kits advertised on the internet - searched for "shed cabana" (I was looking to use one as a pool cabana). That might give you some ideas as to how to frame the roof. "cabanavillage.com" showed some assembly photos, but not for the 5-sided version - they used 2x4's for rafters, and a 2x6 for a ridge beam (which you probably won't have coming to a single point). Hope this helps.
Thanks for the info, I've come across the website while I was doing research earlier, they have some nice sheds. Its hard to find much information on building your own shed let alone roof design and construction.
I decided on 2x6 for the rafter construction, it might be overkill for this sized roof but I figured it cant hurt. There is a program out there you can try that can calculate rafter dimension for you, it has a 30 day trial. It does not have a specific option for a 5 sided roof but you can break it down in sections and use the program to design the rafters. I built the hub last night by stacking 2x6 stock. So if anyone is interested I will post some ideas and dimensions once I cut the rafters and try them with the hub, assuming that everything works and the roof does not fall in
cheers
Jake
cheers
Jake
What are the spans of the rafters? Technically, there are not span charts for 2x4's because the are only for vertical use. A 6/12 roof will have limited snow or dead load, so assuming not a long span, the might work, but your choice of 2x6 is a good one.
Hi Everyone,
Its been a while since I finished the project but being so busy with work these days it took a while to get the photos online. However considering its that time of year people are already thinking about building or buying a shed so this may help people decide on a kit or DIY project. The shed took several weekends to complete (longer then expected) but I was happy with the end results. Materials cost about $700-800 but about a 1/4 of what most kits cost and I think with better quality materials.
Here is the link to a few pictures of the completed shed and some construction photos.
http://www.jakeandkaren.com/house/shed.html
Thanks
Jake
Thanks
Jake
