ground anchors....
Old 02-10-09, 07:32 PM
F
ground anchors....
anyone familiar with these duckbill ground anchors that you drive into the ground then connect via the cable to the structure you need to anchor? how effective are they? i've got a 12x20' building i need to anchor. will they work? thanks...
Old 02-10-09, 08:16 PM
Speedwrench's Avatar
if you get them in at least 24in they will work quite well, although i favor the screw in anchors. best bet is to figure the force from avarage winds in your area and divide by the holding force of the anchors to come up with the number of anchors needed.
life begins when the kids leave home and the dog dies
Old 02-11-09, 08:39 AM
F
thanks. second question, do i need to buy the driving rod they sell for the anchors ($50 or so) or can i just get a length of rebar and use that?
and how do i figure the force from average wind?
Old 02-11-09, 09:16 AM
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
The wind pressure, q = .00256V^2 (V is in mph)
Got this from another board...not sure if its correct...but it gives you the force per SF.
So...say you have a 50mph wind against a 20' x 8' flat wall (160SF)
.00256 x (50 x 50) x 160
.00256 x 2500 x 160 = 1024 lbs of force against the structure.
Can't guarantee this is correct...Its not taking into account roofs or quartering winds or anything else.
Old 02-11-09, 12:57 PM
F
thanks gunguy.
another question. if an anchor is rated for 1100lbs and i have say 6 of them around the building, does this mean i have 6600lbs protection? or maybe 3300 since it would be 3 on each side of the building?
Old 02-11-09, 01:12 PM
Gunguy45's Avatar
Super Moderator
I would say you have 3300...since the wind really only can blow one way at a time.
As I said..I'm sure theres more to the calculations than that.
I would check with your local Codes office and see what they would require for your structure.
