Rotten Timber Panels
Old 05-25-13, 06:13 PM
Hey guys,
Please see attached pictures. I wish to repair or replace the timber panels that are rotting.
Option 1: Repair and weather proof paint the timber panels
Option 2: Repair and put clear roofing sheets to avoid this from happening again due to rain
Option 3: Repair/replace timber panels and put clear roofing sheets.
What do you think?
Is anyone here able to suggest/recommend options - costs involved?
Appreciate your time. Thank you.
BJ
Old 05-26-13, 03:29 AM
Received 741 Upvotes on 647 Posts
Welcome to the forums!
Looks like some of them need to be replaced. Hard to tell from the pic how bad the rot is on each beam
The paint/stain on the top edge of the beams often doesn't get painted [or stay painted] like it should. The unseen top of the beam receives more abuse from the weather than the rest. Whenever I stain beams like that I like to double coat the tops.
There are some that don't even apply the first coat because you can't see it from the ground
Old 05-26-13, 04:04 AM
hi Mark,
Thanks for the reply, looks like they do need replacement, I was hoping repairing and painting them would do the job but that may not be worth the money. I have attached another picture.
Old 05-26-13, 04:07 AM
Repairing might extend their life some. The biggest problem with repairs is they are only as strong as the wood it's attached to. It's highly likely that the remaining wood isn't solid/dense as it once was and will absorb moisture over time which leads to the failure of the repair. Looking at the wood from above will give you a better idea as to the feasibility of repair.
edit; just saw the new pic - I'd replace any wood that looks like that.
Old 05-26-13, 05:18 AM
Received 1 Upvote on 1 Post
#1 Please go back and add your location to your profile, yes it makes a big differance on questions like this.
Where's the water suppost to go if you add those panels?
Those spans are way to long, undersized and the beams are way to far apart to be building what will amount to a flat roof on them.
I'm just not a big fan of any of those plastic panels, hard enough to keep them from leaking when there installed on a slope, laying them flat I'd se no way to stop it from leaking.
Old 05-26-13, 05:34 AM
Joe - he's in Australia
I was addressing option #1 and forgot all about #2 & #3
Old 05-27-13, 05:10 AM
Hey guys, thanks for the suggestions, looks like replacing some of the really bad ones is the way to go. I'll keep in mind about the double coating as well.
any other suggestions welcome!
