Go Back  DoItYourself.com Community Forums > Garden and Outdoor Center > Greenhouses, Sheds and Sun Rooms
Reload this Page >
How to fasten shed floor to concrete column footing?
Old 07-31-13, 11:53 AM
Hello, This is my first post on diy.
I am putting in a corner shed that 10x10 and has a corner removed ie. the door will be at an angle. The shed has 5 corners.
I've decided to use 2x6's for the floor and have the floor rest on concrete footings set 4' in the ground.
There are 8 footings. One for each corner, one between each of the back sides and one to support the door step.
My main question is, how should I fasten the floor to the concrete ?
Thank you.
Old 08-01-13, 08:06 AM
Go on the Simpson Strong Tie web site and look at the post bases and caps.
Got a picture of this lay out?
Old 08-01-13, 10:01 AM
From looking at the site, I can't see too many options. The elevated post base might work for #2, 5 and 8.
Would an anchor bolt with a block work - with the floor being connected in some way?
I need to make sure if I set anything in the concrete that I have some wiggle room when placing the floor.
