Go Back  DoItYourself.com Community Forums > Garden and Outdoor Center > Greenhouses, Sheds and Sun Rooms
Reload this Page >
Using recycled vintage windows - framing question
Old 05-04-14, 07:49 AM
I want to build a potting shed and use some old, wood-framed windows with zinc caming from my step-grandmother's house. When I frame for the windows, how much space should I allow around each opening for the windows (there are two sizes and I'll be using both, hence my vagueness about specific sizes)?
I know I shouldn't make the openings super tight, but my familiarity with replacement windows is limited to vinyl-framed new or like new windows. Wha's a good gap?
TIA!
Old 05-04-14, 08:24 AM
XSleeper's Avatar
Received 714 Votes on 661 Posts
If the RO is 3/4" to 1" larger that will be plenty of room to level and square the window. You will shim the 4 corners with cedar shims as you level and square it up.
Old 05-05-14, 12:06 AM
Thanks! That's exactly what I needed.
