24" stud spacing vs 16" stud spacing
Old 08-04-14, 06:18 PM
U
I'm building a small workshed (12x16f) and I'm wondering which one would be better. Going 24" will save me about 30% or so. However, 16" is more standard and stronger.
I'm wondering if going 16" really matters. It's not like I'm building a house. If they build homes with 24" then why can't a build a shed?
I keep reading about how 16" is really better, and also about how 24" is perfectly fine. Can someone please clarify for me? I don't want to build a bad structure, but I can't do an expensive one, and spending more money on framing means less money to go to other parts that could really use it.
Old 08-04-14, 06:44 PM
XSleeper's Avatar
Received 712 Votes on 659 Posts
Unless you have some seismic requirements or some sort of local code that we don't know about, 24" on center is fine, but I would recommend you step up to 5/8" roof sheathing so that you can skip the h-clips that are used with thinner roof sheathings when 24" OC is used. You will want your rafter layout to be inline with your studs.
Old 08-04-14, 07:19 PM
Tolyn Ironhand's Avatar
Received 217 Votes on 192 Posts
The only time houses can be built 24" OC is when using engineered trusses. Hand framed is almost always 16 OC.
Old 08-04-14, 07:37 PM
chandler's Avatar
Received 6 Votes on 6 Posts
I don't see the 30% savings. Maybe $35 total in wood. You can do it, no problem.
Old 08-05-14, 04:31 AM
Received 330 Votes on 293 Posts
What type of siding do you intend to use? Thinner sidings may wave in/out on 24" centers.
Old 08-05-14, 05:12 AM
Norm201's Avatar
Received 253 Votes on 227 Posts
Spend the extra on 16" centers. Later on you won't be sorry.
