Small solar system
Old 08-24-08, 07:28 PM
Small solar system
I'm going to be building an outdoor bar at my pool and I thought it would be a great idea to make it self-sufficient for power. I would need enough power to run a small, bar-size refrigerator, stereo and small LCD TV all from a solar system with battery storage, inverter and panels and whatever else. The area gets tons of sun but I don't know if it is worth the effort especially for a novice. Am I looking at mega-bucks?
Old 08-24-08, 07:54 PM
GregH's Avatar
Super Moderator
Received 38 Votes on 36 Posts
Solar power is quite impractical for all but very low drain devices.
One panel I looked at produces 80 watts in full sunlight but costs $750.00!
A bar fridge alone could consume 300 watts when running so if you are in a warm climate it could run at least 75% of the time.
You would need several panels to power up what you propose along with batteries, a charging system and inverter.
Pretty much qualifies for mega bucks.
(Let me know if the link does not work)
Old 08-25-08, 12:34 PM
Thanks. I saw that one too (the link works!). I am in southern Ontario and since last night I did some power-use calculations on the fridge, stereo, etc and I think you are right about the mega bucks for running these from solar. The roof of the bar would be too small to hold all of the panels I would need.
Thanks for the confirmation.
Old 08-25-08, 07:28 PM
X
But solar pool heat is very do-able.
Old 09-27-08, 03:14 PM
W
wwc
wwc is offline
Wow i had no idea of the prices to run solar power.
I too was wanting to run a home fridge or maybe a small bar fridge for emergency power outages and a tv to keep updated but I would have to do it all WAY cheaper than that.
I was thinking of a 15 watt cell a 7watt charge controller,800 watt inverter,and deep cycle battery.
Was i dreaming? Is it possible ?
what can i run on this set up?
Old 09-27-08, 07:05 PM
GregH's Avatar
Super Moderator
The math on this is quite simple.
If you have a power source which would be your solar cell that puts out 15 watts, that power source could power 15 watts continuously.
If the sky were to cloud over for a given amount of time when the sun came back the solar cell would have to supply the power for the device as well as charge the battery.
A 15 watt cell is just a toy, good for a couple of very small lights at best.
Old 11-27-08, 10:49 PM
W
wwc
wwc is offline
wow that sucks, I had no idea.
so even with a battery for storage i couldn't run a small bar fridge most of the day to keep food cold or frozen ?
Old 12-05-08, 07:37 PM
Kodiak_314's Avatar
Since this is a DIY forum has anyone thought about building their own panels? Im in the process of build a few myself and although they arent the top of the line megabucks panels they will easily have a combined output or a midrange panel.....say 60-80 watts.
has anyone tried to build their own with an success?
Old 12-06-08, 10:32 AM
GregH's Avatar
Super Moderator
My "belief" on this is that a manufacturer can buy the cells for a much lower price than a hobbiest making DIY impractical.
Have you researched the price of the raw cells?
Would be interesting to know if it was feasable to DIY.
Even if a panel could be built more cheaply it still doesn't make the output of a cell high enough to be feasable to power high current draw devices.
Old 12-06-08, 11:26 AM
Kodiak_314's Avatar
Solar cells arent powering the devices directly....they are charging the banks of batteries used to power the devices....either 12 volt or through an inverter.
I have a decent amount of individual cells that I am in the process of connecting with ribbon before I install them inside an enclosure. Thats what DIy is pretty much all about.
Old 12-07-08, 08:03 AM
N
New Member
This *might* get you going. Small 12v fridge, power from 12v battery, battery charged by solar panel:
Solar-powered refrigerators by Jeffrey Yago, P.E., CEM Issue #102
It's not an ad - just some reviews of some alternatives to grid-based refrigerators.
Hope this helps.
Tom
Old 12-10-08, 09:41 PM
gfking01's Avatar
Post Standalone versus Grid-Tied Systems
I think I'd recommend a grid tie solar system. You didn't mention anything about the amount of wind you receive on average. There are combo solar/wind grid tie systems that are under 2k available that would probably be more cost reasonable and practical I would think. Something like this might be a better thing to consider.
