Wind power, whole home approach
Old 01-23-10, 03:43 PM
Pendragon's Avatar
Received 2 Upvotes on 2 Posts
Looking for someone who has installed a wind generator that has substantially replaced their utility supplied power.
What did you install (size, model, etc), where are you located, what was your average power usage before, after, etc.
Old 01-23-10, 03:53 PM
B
Received 47 Upvotes on 43 Posts
I looked at some DIY small units and they just don't put out enough power. The home sized units that I could purchase would need a major cash investment, plus the house demand would have to be significantly reduced.
With the improvements in electrical use by appliances, once you switch out the major units, hot water to solar, cook stove to gas, and all of the lighting to high efficiency, there isn't a lot to save, thus difficult to justify.
Now if you are living off the grid, I would look at some DIY projects. Here is some fun reading: BuildItSolar: Solar energy projects for Do It Yourselfers to save money and reduce pollution
Bud
Old 01-23-10, 04:12 PM
Pendragon's Avatar
I was looking at some of the ReDriven units. I've got an email out to them, but apparently the only person that can answer questions is out on vacation. Silly canucks.
Anywho, the 10kw unit is about 20 grand, not including the tower (no mention on cost of the tower). I particularly liked the tower, as it can be raised and lowered hydraulically for servicing the generator, or in my case, lowered for inbound hurricanes.
*Assuming* that model could replace my PoCo, I'd see a payback in about 7 years, after that it would be essentially free power.
Except for central heat/air and the electric water heater (which I'll be switching to gas when I can), my electrical demand is pretty low, as I can run my whole house, sans the heat pump), on a 6500 watt generator and it's not even taxed.
Unfortunately, not much I can do about the heat pump, it's just a big hog.
I'm still looking for some CT sensors that will fit over my 200a SE entrance cable so I can find out what my actual load really is.
Old 01-23-10, 04:27 PM
B
I don't see the payback. I have friends in Florida and $100 a month is high. Even if I give you $200 a month, the $20,000 plus tower, plus controls or what ever always pops up, a true payback would be over 15 years. The only thing we can't figure in is the future cost of energy and I have to admit, being prepared does feel nice .
Bud
Old 01-23-10, 08:19 PM
Pendragon's Avatar
Actually my leveled bill is just a touch over $300 a month right now.
I'm averaging about 65 kwh a day, I sure wish my bill was $100!
Since I'm not sure how they are calculating the power, I don't know which unit would be appropriate. On the surface, the 10 kw unit sounds like it wouldn't even handle a sixth of my power needs, yet I've read stories all over about folks with these units that have them with so much power left over they are selling it back to the poco.
Old 02-05-10, 07:35 AM
Location: 54935, planet earth, star sol, galaxy Milky Way
Not windy in Florida
Florida is a poor location for a wind turbine. I'dd whittle down costs in other cheaper ways. Solar siphon water heater is perfect for florida. If there's any water nearby use it as a thermomass for the heatpump. Insulate, shade, trees etc
Old 02-14-10, 08:43 AM
TTASHA's Avatar
We used to have SUN in Florida
Why not solar? Cost is one good reason, however, I recently had a 5kw solar panel installation. One great thing is the 30% tax rebate in 2009/10.
The system is connected to the grid so I get credit when I send power back to Florida Progress. Was I surprised when I saw the meter running backward? Yes because I didn't know such a small installation would make enough power to do this.
Since my installation a month ago we have had very, very cold days and very, very little sun.
This system also provides a connection to the internet to view all the panels and the output per day, month, etc. This is monitored by a company called ENPHASE (pv array). I can see each panel and the enery produced.
If anyone is interested I will tell you how this turns out at the end of the coldest/cloudy days we have had in 20 years.Beer 4U2
Old 02-14-10, 09:20 AM
esalman's Avatar
I agree with TTASHA, the sun shine state would be a great location for solar. I'm looking into installing a wind turbine. it is very breezy her in shrewsbury, specially during the winter months. Because the heat is on and the light are turned on for a longer periods of time my electric bill in winter is higher than the summer.
