Solar panel to operate 5A coffe maker?
Old 08-10-10, 08:57 AM
The park where I work wants to set up a demonstration solar panel that will operate a 12V coffee maker that apparently draws 3 to 5 Amps.
The solar panel they have is 600 watts.
No-one here is very knowledgeable about electricity. How can we determine if this will work?
Is there a formula that we can use? A site that gives answers to questions like this?
Thanks,
Tom
Old 08-10-10, 09:46 AM
Watts = volts X amps. You are looking at 360 to 600 watts. By feeding a 12 volt battery from the solar panel, you should have plenty of power for the coffee maker. The big draw is when it is perking, which should not be too long.
Old 08-18-10, 01:40 PM
Check out this little guy -> Coffee Maker
Get a deal on it with this -> ***************
Old 08-21-10, 02:27 PM
a 600w solar panel is way to much for a coffee maker you would have to connect the coffee maker to a 12v battery, to get the power off the batter you would have to use a power inverter that converts the power to 110w so you coffee maker dont go boom
Trackbacks are On
Pingbacks are On
Refbacks are On
