Tool for Removing Wood Around Floor
Hi all,
I am a new home owner and recently found out that I had termites in my garage. My exterminator recommending removing the based wood around the floor of the garage to prevent further infestation.I believe that this was left over from when the house was being built as a frame. The wood was covered with concrete and painted. However, it is about 3 inches think and extremely hard to remove. This is partially because it is joined to the floor with concrete. I have tried using a crow bar and hammer to remove the wood in front of the garage to house door. However, this did not work and I had to break off small pieces of wood at at time with the crowbar. To make matters worst, the next portion of the wood to be removed is under the garage wall (dry wall). Is there a specialized tool for doing this job? How can I get this done quicker and properly?
I've place pictures of the problem area on the follwing website. I'de really appreciate any advice that you can offer.
Pictures of Problem Area
http://basewoodproblem.8m.com
Thanks!
Thanks!
Mr. Kiss
Received 0 Votes
I couldn't get your links to work....
I would try a wide putty knife place over then under the wood while striking it hard to displace the bonds between it and the concrete or drywall.
Mr. Kiss
Received 0 Votes
Wow,
Looked at the photos and all I can say is "you have a mess"...
I think I would try to locate an air or electric chisel and use it to work around the parimeter. Local tool rentals should be able to help you out.
Good Luck,
L
Good Luck,
L
