Removing toggle bolts
Old 10-17-02, 03:30 PM
mariah13
Would someone please tell me how to remove toggle bolts from a hollow wall????? Thank you.
Old 10-17-02, 05:52 PM
tedn333
You should be able to back the screw out by keeping constant out pressure on the little flange that is now sucked tight to the wall. Use a little pry bar or even a dull kitchen knife wedged under the flange while you turn the screw out. Keep in mind that the screw may be quite long on a toggle. Once the flange is out far enough just grab it with a plyers and finish the job. The toggle will eventually fall inside the wall. Hope this helps.
Old 10-18-02, 12:41 PM
mariah13
Thanks TedN333
Ted, Thank you for your help. I did not realize the bolts were so long. Will give it a try. Thanks again. mariah13
