Masonary and Brick screws
Old 05-28-04, 12:27 PM
Devinj
I have two brick attachments I need to make: one is a chimney cap that needs to be drilled into brick. The other is for shelf brackets inside going into a brick wall.
I have a power drill and can get masonary bits. Do I pre-drill into the bricks and then get masonary screws? Or do I have to use some sort of plastic inserts hammered into a drilled hole? I'm not concerned about strength on the chimney cap, but what is my best weight bearing option for the shelves ( 2.5 feet, for books).
Thanks, and sorry if these are basic questions.
Devin
Old 05-28-04, 07:44 PM
I find that the plastic anchors work well. Be sure to inject some caulking compound into the holes in the chimney to keep water out.
Old 05-28-04, 10:41 PM
OudeVanDagen
These will work very well (fast and easy but very secure) for that chimmney cap:
http://www.confast.com/products/metal_hit.asp
These will also work for your shelving:
http://www.confast.com/products/tap_con.asp
or
http://www.smithfast.com/polyset.htm
Check the tech data sections for strength charts
