Anchoring Plazma TV to Wall
Old 07-10-04, 08:02 PM
[B]I have a special holder to fix to a wall to hold a plazma TV. This fixture was manufactured in Japan and is not specifically designed for US construction. It says to anchor the frame to the wall using M6 bolts. I plan on anchoring it to the studs using lag bolts. Will this be as secure as using M6? The TV is flat and weighs about 66 pounds.
Old 07-22-04, 01:45 AM
P
M6 is 6mm which is a little smaller than 1/4". I have never seen lag bolts narrower than 1/4".
Phil
Old 08-01-04, 04:39 AM
wstender
a #12 sheet metal screw pan head with a washer should fit in the m6 hole if a 1/4" lag won't. A #14 sheet metal screw is the same diameter as a 1/4" lag. #12 screws are sometimes a #2 and sometimes a#3 philips head size, so make sure you have both bits to put in your screw gun (you don't want to try to put these in by hand!). Use a 2 1/2" and drive them into studs with a screw gun and it won't be going anywhere . Enjoy the view!
