fastener for aluminum siding
Old 12-07-04, 12:33 AM
david13
Does anyone know if those "Command" adhesive hooks will stick to aluminum siding, well enough to hang a holiday wreath? My wreath is under the 5-lb limit that the manufacturer suggests. But never tried these on aluminum siding. Thanks in advance for the help.
-David
Old 12-07-04, 06:20 AM
majakdragon's Avatar
3M claims they will stick to any smooth clean surface. If your siding is the "rippled" type, they may not work. They also must be applied at a temp over 50 degrees. Cleaning must be done with alcohol. Good luck.
Old 12-07-04, 07:31 AM
david13
Thanks for the temp warning. I'm in Michigan, so I'll have to warm up that siding before applying.
