techniques on how to remove broken bolt
Old 02-15-05, 10:04 AM
T
Any ideas on how to take a small bolt out of a waterpump . head snapped off. bolt is flush with surface. It's in a tight spot...so i was hoping to use my rotary tool(dremel). U think this is feasible with a drill bit and tap?
Old 02-16-05, 04:46 AM
pgtek's Avatar
Received 1 Vote on 1 Post
hi
you might used and e-z out.
you can find them at your local hardware store.
you drill a hole first then inser the e-z out and should work
cheers
pg
Old 02-16-05, 10:00 PM
nomind's Avatar
Location: langley, in sunny fraser valley, bc , near vancouver
Hi TileInEye,
- I would support what Pgtek says about using an E Z E out. You can get them at auto supply stores as well. - However I wouldn't use the Dremel to drill a hole, it's much too fast for drilling hard steel. You need to start with a drill speed about 450-700 rpm and LOTS of lube, to drill a clean hole in a steel bolt.
Do it Right - Do it once.
Old 02-19-05, 02:53 AM
K
Small bolt? Consider grinding a slot (for slot screwdriver) with the Dremel's cutoff disk.
