Go Back  DoItYourself.com Community Forums > Hardware, Tools, Wood & Metal Working, Home & Business Security > Hardware and Fasteners
Reload this Page >
fasteners for rigid foam insualtion? (Question Moved To Fasteners)
Old 04-20-05, 04:40 PM
dave61
Does anyone know the best method for attaching 1" or 1 1/2" rigid foam board to the inside of rafters in a cathedral ceiling?
The rigid foam will be taped along the seams and then covered with drywall which will be screwed through the foam board.
Any ideas welcome.
Dave
Old 05-02-05, 03:34 PM
fasteners
Rigid foam is fastened to walls with special nails that have a large counter
sunk plastic washer under the nail head. I believe the same kind of nail
would serve your purposes also. You need to give the nails a couple of
extra whacks to be sure the nail and washer are flush with the surface of
the foamboard.
Old 05-06-05, 02:02 PM
Ed Imeduc's Avatar
Check the big box stores There is a glue for the foam you can use .
ED
Old 05-07-05, 07:39 PM
Be careful with your adhesive selection
Some will turn the foam into goo
Be sure to get the right one
Old 05-16-05, 09:05 AM
mdesciscio
I myself use a powder pin with a large washer. I get the yellow loads and dial it down to the lowest setting for wood. Secures it just fine.
there may be other methods also
Old 05-16-05, 10:56 AM
Question
What's a powder pin?
Old 05-16-05, 01:52 PM
mdesciscio
Here is the pin
http://www.simpsonanchors.com/catalo...tml#300plastic
powder actuated guns.
Old 05-16-05, 02:27 PM
Ah, thank you
My power nailer did come to mind when you mentioned the yellow loads
But I've never heard it called a powder pin
Makes sense now
I had know idea there were those...different fasteners available for it
I'm sure that will come in handy
Thanks for the tip!
