Lag Bolts in Metal Stud
Old 05-18-05, 11:57 AM
RobDub
I'm trying to fasten a counter top with sink onto a wall rather than building a cabinet. I purchased a heavy duty shelving bracket and some 2 1/2 inch long lag bolts thinking that would do the trick. When I found the studs to mount onto I also found out they were made of metal. I was under the greenhorn assumtion that studs were made of wood d'oh!
So can I continue to use my shelving bracket with lag bolts or should I just switch to a cabinet? If the lag bolts are OK how to I get them into the metal stud? Is there a better type of bolt to use?
Thanks, Rob
Old 05-18-05, 05:57 PM
GregH's Avatar
Super Moderator
Received 47 Votes on 45 Posts
Rob,
In order to fasten anything with weight to a metal stud wall you need to span several studs with a backer board that has several screws per stud.
This is just a guess because you don't say how deep the counter is. You may be able to do it with a piece of 3/4" plywood that spans three studs from the floor to the height of the counter with at least five screws per stud.
I would say it would be simpler to use a cabinet.
Metal studs are a curse in commercial jobs when something heavy has to go on the wall.
Old 05-18-05, 10:48 PM
When I have to attach something to a metal stud I use a self-tapping screw
It looks more like a lag bolt as it has a hex head
I have attached shelving in commercial (heavy use) applications with no problems
I get them at the local hardware store
Never done a counter with a sink though...
That's gonna need to be pretty beefy
I like GregH's plan for that
