Ramset?
Old 12-12-05, 08:33 PM
dkpbxman's Avatar
Question Ramset?
I've been thinking about adding a 1/2 wall by the door to give me a "mud" area seperated from the living room.
The house was built on a concrete slab so I assume I'd need to to secure the bottom plate of the wall to the slab with a ramset or something.
What would I need as far as caliber, type fastener, etc.?
Thanks for any help,
Dan
Old 12-13-05, 03:44 AM
GregH's Avatar
Super Moderator
If you have not used one before a powder actuated tool would not be my first choice.
There are many types of anchors available that only need to have a hole drilled to use them.
http://doityourself.com/concrete/h2anchorconcrete.htm
Old 12-13-05, 04:23 AM
dkpbxman's Avatar
Thanks for your reply.
Is your concern that there are better methods or more safety based?
I was extensively trained on and carried/used a .38 cal pistol for 16 years with no problems.
I am very familiar with "powder actuated tools".
Old 12-13-05, 05:59 PM
It's hard to say
You can go by the manufacturer's charts, but when it come to the real world, they are just guidelines...perhaps that's what GregH was refering to
Age, quality, unknowns in the concrete make it...not quite precise
As GregH says, there are many types of anchors available that only need to have a hole drilled to use them.
If you want to use the P/A, ask at the place you rent it from for advice, and get a couple of different size fasteners and loads, if the recommended ones don't work out, you'll want to have some others to try
Old 12-13-05, 09:31 PM
Typical of wood frame: 1/4" framing anchors (drilled hole). On a long wall supplemental pins shot with yellow loads near every other stud (while straightening the plate).
Pins alone do not have the holding power or the shear resistance of the anchors. Can you use power pins alone. Yes. Is is smart. No.
Since it's a mud wall partition think about using Hi-Abuse (Impact Resistant) sheet rock with a mildew inhibitor.
Old 12-14-05, 08:35 AM
dkpbxman's Avatar
Thank you
What I wanted to know.
