Attaching PVC railing to bluestone
Received 0 Votes
Please advise best method to bolt/screw PVC railing to bluestone and driveway pavers without damaging.
Depending on the size of pipe you are using, buy corresponding sized metal plumbing flanges which have screw holes in them and a threaded middle. Screw the flanges in the desired location as termination points. Buy the same size slip-IPF pvc fitting, screw it into the flange and glue the proper length into the slip end.
I would not like to test such on my 78 year old mother. Today's glues are great and some will adhere under water, even, but in this particular application, I don't think I could recommend glue.
