How to bond wood to metal?
Received 0 Votes
Hi,
I need to bond an end of a wood dowl to an angle bracket (alumunim). Both materials will be flat and I'd like to make the bond very strong as it will be supporting a camera and needs to be a permanent bond. I have Gorilla Glue, 5 minute Epoxy, Super Glue - would any of these or something else be appropriate?
Thanks!
Bob
Thanks!
Bob
Received 0 Votes
Of the three adhesives you mention Gorilla Glue would be the best choice.A better choice would probably be an epoxy putty such as PC-7 or even JB Weld.All that said you should be prepared for this to not work out.Bonding a wood dowel end to a metal flexible bracket will be a challenge.If possible you might want to drill a hole in the bracket and screw a wood screw into the dowel for re-enforcement.Predrill the dowel to prevent splitting.
Agree, I wouldn't want to trust glue to hold up any of my XE7s. Drill and countersink a screw into the aluminum and predrill the dowel to prevent splitting. Use the glue, also, as it will help keep it from turning around the screw.
