removing stuck cabinet door pulls
Old 05-21-06, 01:20 PM
C
I'm changing the pulls on my kitchen cabinets. About half came off very easily. On the others the porcelain part has come loose from the brass stem that runs through it so when I turn the knob while holding the screw the porcelain turns but the stem won't budge. If I try to turn the screw while holding the knob the screw turns the whole brass piece. What to do to get these off without damaging the wood door?
Old 05-22-06, 11:25 AM
jatco's Avatar
Received 1 Vote on 1 Post
You might try wrapping a cloth rag around the brass part and hold it with a pair of plyers then unscrew the screw from behind.
