Stripped Screw Underwater
Received 0 Votes
Tried to change the pool light today and the screw that holds the light into the wall is now stripped. Can't really use the normal method of a drill to remove the screw since it's under water. Any ideas?
Thanks.
Thanks.
Not sure what type pool light you have, but do the instructions allow for removal while filled with water? Most of the ones I have seen have to be changed dry, or the water will fill the well where the light was. Although the light is only 12 volts or so, putting it back in a hole filled with water won't make it dry. Just thinking out loud.
Received 0 Votes
My understanding is that you can unscrew the one screw and then pull the whole waterproof fixture out of the pool as there is enough cord to allow you to get it to the pool deck and then change the light and re-install. The problem is that the one screw that needs to be removed before I can pull the fixture out of the water is the one that's stripped. I can't put a drill down there and I would really prefer not to drain the pool.
You could try a very small punch or chisel (sharp) and hammer. Hold the punch/chisel at an angle at the outter edge of the screw head and tap in the correct direction. This is very risky in a plastic fixture since you have to hit hard enough to make a dent in the fastener for the punch/chisel to grab, so it is very easy to do some damage if you are not careful.
Received 0 Votes
there is a screw removal tool that looks much like a drill bit called an "easy out", it is designed to remove stripped screws without the proper screw driver bit. If you can find this bit you maybe able to use a tapping tool instead of a drill to remove the screw.
Received 0 Votes
Thanks.
Thanks.
If it's the hole/thread combination - I usually try to find a way to get a flat blade screwdriver between the head of the screw and the surface in question. Then I apply a twisting pressure on the blade while lightly turning the screw head - I find that if I can get it to start coming out - even just a bit - it usually "bites" after a couple of turns and continues to come out of the hole.
