Hanging a hook on drywall - does it have to be on a stud?
Received 0 Votes
I want to hang a hook to support about 5 lbs on drywall. Not sure of drywall thickness but it's pretty thin.
Do I have to make sure to fasten the screw on a stud, or can I use a plastic anchor (the kind that expands in the wall) anywhere along the wall? Or, do I need something else entirely?
TIA
TIA
The big box stores have all kinds of set up for what you want. Have you seen the new hook to use for this it looks like a loop of wire is all makes a very small hole in the drywall, Will hold 50 lb. You can take it out if you want.
ED
ED
Received 0 Votes
Thanks ED!
I went down to Lowe's and they do have a dizzying selection! Pretty user-friendly too. Everything is color-coded for the type of wall/weight of the object, and the package even says what drill bit to use.
The diagram in the store showed the fasteners attached to a thin panel. They all have some sort of mechanism that springs open or expands once they are inserted. I assume that means they do not have to be used on a stud, but can go anywhere along the wall.
I am painting a wall - first time ever for that, too! - so I can experiment a bit and then spackle over it. Maybe I will even "accidentally" hit right on a stud, LOL!
Received 0 Votes
Originally Posted by Falconress
...Maybe I will even "accidentally" hit right on a stud, LOL!
Received 0 Votes
Thanks - that's great advice. I did try "tapping" the wall but couldn't feel a difference, and it didn't seem worthwhile to buy a stud finder for this one silly little job.
I will go slowly around the area where the electrical outlet is located because I understand that this is probably mounted on one of the studs.
ED
ED
they are doing infomercials for them and they say they can hold 150 lbs . I bought a pack at home depot awhile back and it says 35 lbs.
