Cutting Brass Door plate
Old 02-21-07, 08:00 PM
U
Help. I bought a 30" wide brass door plate and new to cut it down by 2" or so in length. What's the best thing to use to make a nice straight even cut, obviously keeping safety in mind?
Thanks.
Old 02-21-07, 09:24 PM
XSleeper's Avatar
Received 856 Votes on 784 Posts
The problem with cutting the brass (if it's a thin shiny plate) is that you can bend up the edge which will look really bad. I'd suggest you try taking it to a plumber's shop and see if they can cut it for you on their sheet metal shear.
If I had to do it, I'd screw it to a solid piece of wood so that it doesn't move (through the scrap side of the plate) then would try clamping a straight edge onto it and would score it 5-10 times with a carbide laminate cutting knife until it weakens enough to score and snap.
I've cut some thick door plates on a table saw with a carbide blade, but I hesitate to recommend that to others- especially not knowing the thickness of the piece you are working on. Thicker would be better- thinner might irrepairably bend if it caught a tooth just right.
Old 02-22-07, 08:55 AM
U
Yeah. I was wondering if I could cut in on my table saw. It looks like between 1/32" and a 1/16" thick.
Anyone else have other suggestions?
Old 02-22-07, 11:21 AM
W
Received 29 Votes on 26 Posts
Cutting Plate
Try a jig saw with a very fine metal cutting blade. Tape the plate so it does not get scratched by the sole plate of the jig saw. Good luck.
Old 02-28-07, 08:02 PM
U
Smile Feedback for all advice given
Dear all,
I wasn't comfortable with the jig saw idea, I didn't have a plumbing shop nearby, and I don't own a carbide laminate cutting knife. Sooo... I bit the bullet, used the mounting holes provided on the brass plate and screwed the plate to a 3/4" scrap pine board that was wider but a bit shorter than the plate (making sure the whole thing was squared up, of course). I sent this through my table saw slowly but steadily, using a thin kerf carbide rip blade. The blade performed flawlessly. I cut each end by simply moving the plate so that it was fully supported by the scrap piece. When finished, I took a metal file and gently but firmly filed the burr off that was created on both sides by the saw. The finished product was perfect. The company (National) had even mounted a clear plastic protective cover on one side, which I used as my top up side on the table saw. By the way, don't bother calling them- they couldn't give me good advice on cutting their own plate! The whole thing took me less than 15 minutes. Boy, was I thrilled.
Old 02-28-07, 08:53 PM
XSleeper's Avatar
Nice job. Good thinking by putting the backing on there as you cut! Glad it worked out.
Old 03-06-07, 05:18 PM
chandler's Avatar
Received 6 Votes on 6 Posts
And I was going to suggest a plasma cutter....Oh well, glad it worked out well.
