Mounting 50-70 lb. Mirrors
Old 03-05-07, 08:53 AM
U
I recieved 3 old mirrors from an Barber shop. The only thing wrong with them was a few chips from the sides. I made some nice frames and covered the frames with faux leather, mounted the mirror inside.
Now I'm ready to mount them to the wall. I can definately hit 2 studs but not even at the back of the mirror. what can I use that will hold about 70 lbs, and not have the mirror stand out from the wall more than it has to?
Old 03-05-07, 10:23 AM
D
mirror hanging
There are fasyteners that will hold the weight you are talking about.
I usually use two fasteners separated by 25% 50% 25 % of the width.
If you can hit the studs place the fasteners in two of them. Use twisted oicture frame wire.
You did not mention the mirror width
Danbrew
Old 03-05-07, 11:42 AM
U
the width of the mirror ( including Frame ) is 33" the height is 51". I have 3 to hang on a aprox 15 foot wall.
Old 03-05-07, 04:36 PM
You don't need studs to mount mirrors unless you want to remove them later. By that I mean use adhesives, go to a glass/mirror shop and they'll hook you up. Don't use PL or similar adhesives found at HD or Lowes.
Old 03-06-07, 03:44 PM
chandler's Avatar
Received 6 Votes on 6 Posts
Some EZ-Anchors are rated at 90 lbs of vertical weight each, so if you decide to attach them not using the adhesive, they will work with standard mirror holding pieces.
