Purpose of washers
Received 0 Votes
Purpose of washers
Planning a project and it calls for washers. Though I know I'm going to use them, I'd like to know the purpose of them. At least this way I know the purpose of them on any other projects.
The purpose of a washer is to provide strength around the hole the fastener is passing through.
It also provides a firm base for the fastener when it rotates as it is being tightened.
Washers can be used as spacers as well.
There are more uses for washers and there are also many types of washers.
How do the washers relate to your project?
Received 0 Votes
Perfectly understood
I actually found the washers except I got the wrong size! Doh! I think I did get the fender washers cuz these things sure don't look the normal size. What I did was make sure the lag screws would fit through, however, while I was screwing it through...I forgot to make sure the top part of the screw would fit through the hole and it didn't so I have to go back.
I didn't realize it until I got home and played with it. Sure taught me a lesson on washers and screws.
