Lookin for info on a bracket standard
Old 10-23-07, 04:31 AM
W
We were given a wall system with 3 sections and they only had 3 shelves. we need more. we have tried the standard sizes and they dont fit. Here is a drawing of the bracket with the measurements. Any help on where to buy some will be appreciated. We are either looking for wood shelf brackets or 4' long metal shelves with the brackets. If you need more info, feel free to ask. Thanks!
Old 10-23-07, 06:38 AM
W
Received 27 Votes on 25 Posts
Shelves
Your post is not clear. What exactly do you have? What do you need to add?
Old 10-24-07, 06:29 AM
W
We have the rails to put the brackets on, we just need the brackets themselves or shelves with brackets attached. Thanks for your help.
Old 10-24-07, 07:05 AM
W
Bracket
Found this bracket by Googling "shelf bracket":
http://www.amazon.com/dp/B000OQ9BSW/...W&linkCode=asn
You may have to replace all brackets to get a uniform appearance. Your rail measurements will detremine what brackets will work. Find the rails at your local store and then look for the brackets. Good luck with your project.
Old 10-24-07, 12:09 PM
Several manufacturers make these types of sheving brackets and standards.Suggest you take a standard with you to hardware stores and actually try the brackets in it as they do not usually interchange between brands.
Old 10-25-07, 12:28 AM
W
We have tried that and haven't had any luck. We have also tried 1" centers and 2" centers and neither work. I was looking to see if there was any place that sells 1 1/2" centers.
Old 10-25-07, 05:31 AM
chandler's Avatar
Received 6 Votes on 6 Posts
You may can pursue the dimensions of this manufacturer's brackets. http://hardware.hardwarestore.com/28...et-109026.aspx
