Removing a Rivet
Old 01-15-08, 05:42 PM
Removing a Rivet
Hi,
I assembled some aluminum tubing with EZ Pull Rivets.
Anyone know how can I remove them?
I can't access the underside/backside of the rivet, since its inside the hollow aluminum tubing.
I think they are 3/16" long type.
Old 01-15-08, 06:20 PM
GregH's Avatar
Super Moderator
Drill it out with the same size bit that you used for the rivet.
Old 01-17-08, 05:50 AM
chandler's Avatar
Once you drill it out, however, the waste will be inside the tube, so if you can't access it, it will rattle around for eternity.
