Pilot hole for 5/16" lag screw in very hard wood
Need to drill a pilot hole for a 6" X 5/16" galvenized lag screw into teak. It is to mount a chrome end piece - actually a 7/8" X 1/2 inch chrome socket on a flag pole. The screw will run "down grain" so I am concerned I get adequate bite, but do not want to split the wood.
What size bit?
What size bit?
6" into teak end grain, you need very little bite. Those large threads will not shear the fibres, but rather pinch them, which is good.
The roughness of a galvanized lag screw adds to its diameter, so I think your best bet is to take it to the bit aisle and select whatever bit is very slightly smaller than the screw. I would be prepared to file the screw threads if the fit seems too tight.
