Fastening to Brick
Old 07-13-08, 09:53 AM
Fastening to Brick
I need to attach a garden hose hanger to the brick on the outside of the house. I plan to use plastic anchors. My question is, Do I put the screws in the bricks or can I put them in the mortar?
Old 07-13-08, 09:59 AM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
Put them in the mortar. You could crack the brick while drilling or tightening the screws. Also easier to patch later if its removed.
Old 07-13-08, 10:05 AM
Thanks for the reply. One other question, This hose hanger has 6 screw holes and 4 land in the mortar and 2 in the bricks. Could I take a treated 2 by and attach that to the wall with a couple screws and then screw the hanger onto the board?
Old 07-13-08, 10:10 AM
mango man's Avatar
I would sink a 4x4 post and attach the hose hanger to it
Old 07-14-08, 06:51 AM
W
Received 21 Votes on 20 Posts
Hose Hanger
Scotty, I have a hose hanger mounted as you suggested with 2 2x4's fastened to the mortar joints in the brick. It has worked very well for many years. The 2x4's are treated. Good luck with your project.
Old 07-21-08, 10:52 AM
G
Put a few drops of caulking in the hole that you drilled before you put the anchor and screw in.
