Need harder Staples?
Old 12-29-08, 07:44 AM
Iím installing a 7/16" Mahogany floor and my staples are kinking up a lot. Iím using 1/4" x 1-1/2" Galvanized staples. A friend of mine told me that non-galvanized staples are harder. Is this true and would it hurt that they are not galvanized? Thanks for any advise.
Old 12-29-08, 06:18 PM
chandler's Avatar
What are you shooting the staples with? Won't hurt if they are galvanized or not. Never heard of the strength difference in galv or non-galv.
Old 12-29-08, 06:31 PM
dhamblet's Avatar
Doesn't 1 1/2" seem like a lot of staple for a 1/2" floor?
Old 12-30-08, 05:46 AM
Im using a High Pro flooring stapler and Im using 1-1/2" because Lowes only had 1" or 1-1/2" and the directions on the flooring say to use 1-1/8" min. I have found some non galvanized 1-1/4". Would that work better?
Old 12-30-08, 04:05 PM
chandler's Avatar
Which stapler, they make several. It would help to know.
Old 12-30-08, 09:39 PM
The model # is AS-4090. I have it set at 70 psi.
Old 12-31-08, 05:37 AM
chandler's Avatar
What pressure does the gun specify. I believe 90 psi may do the trick, if it will allow it.
Old 12-31-08, 07:24 AM
The manual says to set it at 70 psi. I bumped it up to about 85 then 80 psi but it was busting the tongue of the flooring.
Old 12-31-08, 07:53 AM
Gunguy45's Avatar
Super Moderator
Hasn't been asked yet, and may not matter.....what kind of subfloor and underlay are you attaching to?
Just wondering.
Old 01-01-09, 09:22 AM
Sub floor is 3/4" OSB. I tried some 1-1/4 staples and that seems to have fixed the problem. I'm not sure why but it did. It could be because it is a different brand. Anyway it works so thats what I'm going to stick with. Thanks for everyones help.
Old 01-13-09, 05:44 PM
HotxxxxxxxOKC's Avatar
Maybe you were hitting a floor joist with those longer staples......
