Smooth Round Head Bolt Similiar to Carriage Bolt
Received 0 Votes
I'm looking for a bolt with a smooth round head with NO DRIVE similar to a carriage bolt but without the square neck. Does something like this exist and if so what is it called??
Received 0 Votes
Its for an arcade cabinet. I would use these bolts to secure the joysticks under the metal control panel. Carriage bolts wouldn't work with the round holes drilled in the control panel. I want a low profile smooth bolt head because its going to be exposed on the topside.
.........o.........
Behold the ascii art of what I'm doing
. The "+" represent the four bolts through the corners of the joystick and control panel.
.........o.........
Bolts
I did a search on "dome head bolts" and this is one of the many hits:
Dome Head Bolt Packs - Pro-Bolt USA Hardware - Titanium, Stainless Steel, Aluminum Fasteners for Metric Motorcycles & Harley-Davidson
Hope this helps. Good luck with your project.
