Replacement Hardware Available?
Received 0 Votes
The plastic shelfing that came installed in my lower cabinet (revolving corner/lazy susan style) has cracked. The cabinet is in good shape otherwise. Is there after-market shelving available anywhere. I do not know the manufacturer of the cabinets. They were installed by a previous homeowner. Everything is supported by a center post. I'm a machinist and can modify almost any hardware to fit.
Received 0 Votes
Plastic shevling indicates a low end cabinet, and may not show a manufacturer name. They don't like to advertise cheap. Make the rounds at big box stores and see if they have something that comes close, they specialize in cheap.
You may be able to fix what you have if you are handy. A brace, bracket, or such, and some epoxy might get you thru to the next new kitchen redo.
