Articulating Mount TV with Metal Studs?
Received 0 Votes
Hi all, I know this has been discussed but this is my concern. Best Buy and HHGreg have both told me that they will not guarantee the install I would like to do and that it could probably not be done by a traditional mount job.
This is what I'm trying to do. I have a 46 inch LED TV. I want to mount it using an articulating (swivel) Chief mount. My condo has metal studs.
I've read other threads that generally say that such a mount is possible. For such a mount, will toggle bolts really do the trick? Will I have to do a non-traditional mount?
Best Buy and HHGreg were both concerned with the fact that I was trying to do an articulating mount with metal studs.
Any help would be appreciated!!
I think toggle bolts will hold if you get them through the stud. The stud has the strength but the metal is just too thin for the threads of a traditional screw to get a sufficient grip. If concerned you could use some wood to bridge across two studs. That way you have spread the load across two studs and you can use whatever size wood you want and install fasteners into the wall until you are satisfied.
I work on commercial spaces a lot. (metal studs 2' OC and 5/8 drywall) Whenever mounting a tv to the wall the framers always install 3/4" plywood for backing between the metal studs and then 5/8" drywall over that. When installing for an even larger tv they ran the 3/4" plywood floor to ceiling. Even with toggles I think an articulating mount would rip the toggles out. I would open the wall and install plywood or wood framing (2x material) for backing. Depending on the type of building, any wood framing might need to be fire treated. Opening the wall would also allow you to install the cabling/raceway and power for the tv.
Received 0 Votes
I got the articulating mount today (Chief Dual Arm PDR) and it is really heavy. Probably 70 pounds when in the folded position alone, more like 90 pounds when extended. That is without the TV.
I don't know if this has been addressed, but how would you go about installing the wood into the stud? I'm a novice and might need more detailed instructions than most.
Would it be enough to nail 2x4s into the hollow part of the metal stud or should I put plywood between the studs and the drywall? I guess while I have the walls open I could do both.
The upside is that the mount is big enough to get to two studs. I am thinking about having a professional take a look.
Thanks for all the help guys, it's much appreciated. Don't want to see my new baby on the floor when I get home one day.
Are most steel studs non structural, used just for partition walls?
Given the weight I would bolt the 2X12 to the 2X2s. To do that you would insert the bolts into the 2X2s and fasten with a T-nut before installing the 2X2. You could also use pre-installed Tnuts in the 2X12 to fasten the support. Use the type of T-nut that has holes in the face for screws. Also make the 2X2s full height. It will strengthen the metal stud and transfer some of the weight to the floor. If you want to minimize the amount of Sheetrock removed use togle bolts for the 2X2s.
Note: With a little imagination you may be able to use Unistrut instead of wood but wood is probably easier to work with.
Edit: The more I think about it the more I like substituting unistrut chanel for the 2X2. Make it 12" shorter then total height and you can slide the 2X12 down the channels after the unistrut is bolted in place. Secure the 2X12 at the proper height with screws. You would need to grove the 2X12 to accomidate the curled lip of the unistrut though.
