Tension strength of a 2.5 inch #8 Zinc screw
Received 0 Votes
I'm planning on installing a 40 lb ceiling fan with two 2.5 inch #8 zinc wood screws. Will these hold up to the forces placed on them? They will be screwed into a ceiling joist.
Thanks,
Adam
Thanks,
Adam
I have had better luck when using the premium, corrosion resistant, deck screws meant for use with ACQ lumber. The steel seems to be higher quality and they seem to be much stronger than cheap wood screws or cheap deck screws.
