What size is this screw?
Old 12-06-10, 08:17 AM
G
I have a part or size screw which I do not understand. It is an M8 x L19. Can someone please tell me if this is a Metric or American Standard size and what do the numbers mean? Thanks BTW, it is the screw that mounts an LED LCD TV to a wall mount. Samsung couldn't help me with that, would you believe? Thanks
Old 12-06-10, 08:37 AM
Gunguy45's Avatar
Super Moderator
Received 4 Votes on 4 Posts
It's metric. The first designates the diameter and the pitch of the threads...the second is the length. Normally you'd see it as M8 x 19.
Old 12-06-10, 09:56 AM
G
Thank you gunguy45 for your response. It was what I needed. I had a remote feeling that the M stood for Metric and it is plain now that the L stands for Length. I wasn't sure what the numbers stood for. I guess 19 means that it is 19mm long. and 8 means 8 threads per mm. I'll have to remember that. Thanks again and have a good Happy Holiday.
Old 12-06-10, 10:16 AM
Gunguy45's Avatar
Super Moderator
Actually...except for the length...I don't know that the M8 means what you said. It's not the same as the SAE system where it's all in the name...ie 1/4 x 20 x 1" (1/4" nominal diameter, 20 threads per inch, 1" long).
The M8 designates several things as I understand, but the M doesn't stand for metric I don't think, and the 8 indicates a diameter as well as a thread pitch (though it can't be 8 per mm, since a mm is very small) if a diff pitch isn't stated in the designation.
Maybe one of our engineer types can give a better explanation.
Old 12-06-10, 12:12 PM
W
Received 27 Votes on 25 Posts
Screw Size
Take a look at this:
How Metric Screws Are Measured | eHow.com
Hope this helps.
Old 12-08-10, 08:32 PM
G
That link was pretty clear. Thanks wirepuller38. I think I know what to look for now. I hope our local hardware stores carry this size. Thank you all for your help.
Old 12-10-10, 02:48 PM
A
Did you find the screw? Seems to me like it's some random size that only Samsung supplies so you buy their official wall mount kit. When I google that size, it only shows up here and in Samsung forums.
