Sticky Kwikset deadbolt
Old 04-28-12, 10:41 PM
L
I've got a basic Kwikset single bolt deadbolt on my front door and it turns very easily from the inside, but when trying to lock or unlock using the key, it's very difficult to turn the key in the lock. Do I need to get a new lock or is there something I can do to make the key turn without getting stuck?
Thanks...
Old 04-29-12, 05:23 AM
Received 330 Votes on 293 Posts
Have you tried lubricating the lock? Occasionally I've had to squirt a little oil in the key hole and then work it around with the key.
Old 04-29-12, 10:35 AM
L
silly me...didn't think about that. A little wD40 helped a lot. thanks.
Old 04-29-12, 10:40 AM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
Our lock Pros hate WD40 except to clean the gunk out. There is a product called Lock Ease (sp?) that I believe is carried by Ace Hardware....basically it's graphite in a liquid carrier. As I remember that's what they recommended...I see TriFlow also mentioned a lot.
It will rinse and clean the cylinder and leave the graphite behind as a lubricant.
Old 04-29-12, 01:21 PM
L
thanks!
Thanks gunguy I'll get some LockEase and put that in there too.
